where do i buy afr heads online
Originally posted by SVT Killer LV
210cc IS HUGE..
210cc IS HUGE..
LS1's may be 205cc stock but look at the design of the ports, they made the ports tall and skinny for a reason, the thin port design promotes high velocity incoming air to build low rpm torque. The huge 210 AFR LT1 design will not flow well at low rpm because of its older LT1 design. To run the 210 LT1 AFR heads you would need very high compression to compensate for low rpm torque loss. Can some one correct me if I'm wrong?
And in the LT1 world, where strokers are the norm, the AFR 210s are a great fit. My 2 cents, of course!
Worked for me, maybe when you tried, the server was down for maintenance or something ..
http://www.tenperf.com/products/afrlist.htm
Quite a few people bought procharger and AFR stuff through Dave @ Tenperf, check him out, great customer service..
--Sean
--Sean
