Where to check for vaccum and fuel pressure
Old Jul 8, 2005 | 05:32 PM
lookingformore's Avatar
Like it says and what should the numbers be? Check sig if needed
Old Jul 8, 2005 | 05:40 PM
OBE1 95Z28's Avatar
Re: Where to check for vaccum and fuel pressure
On the back of your fuel rail is a Schrader valve (like a tire valve). A fuel pressure gauge will come with a hose that will thread onto this valve. With the engine running and the fuel pressure regulator vacuum line connected, you'll see around 35 psi at idle, with the vacuum line disconnected, it should read around 43 psi.
A vacuum gauge can be "T'd" into any vacuum port off the intake manifold (like where the fuel pressure regulator gets its vacuum. A stock engine idling will probably draw around 20 inches of vacuum.
Old Jul 8, 2005 | 06:15 PM
Do the upgrades in the engine change what the numbers should read?
Old Jul 8, 2005 | 06:17 PM
Feenix's Avatar
The cam may change what the vac should read. Probably shouldn't be any lower than 17 though. Fuel pressure should be the same as what OBE said.
DirtyDaveW
Dec 1, 2016 05:37 PM
Alex Barnes
Jan 24, 2015 10:21 PM
nophix
Nov 30, 2014 10:26 PM
Jul 4, 2005 05:00 PM
Burn_Out
Aug 18, 2002 08:49 AM
