where can i get these sensors cheap?
Old Nov 6, 2004 | 06:39 PM
flusz28's Avatar
94 z28 - i need two temp sensors?? they are the sensors that go into the block next to the headers on the motor. had a anitfreeze hose come lose and car got to hot and messed them up.
Old Nov 6, 2004 | 08:04 PM
Fastbird93's Avatar
Re: where can i get these sensors cheap?
Are you talking about the Engine Coolant Temp Sensor, the one on the driver side head just below the header and the other one that's in the water pump???? If so any local parts store should have them for about $10-15 each.
Old Nov 6, 2004 | 08:06 PM
flusz28's Avatar
i have one on the driverside and on the passenger side...
Old Nov 7, 2004 | 08:14 AM
As I said in an email response to you:
They only make one casting for the head, so it can be used on either side. When installed, they are a mirror image of each other, so you will see a tapped hole on the rearward side of the passenger head. The 4th gen only uses one sensor and It is factory installed on the driver’s side. There is no harness wiring to accommodate a second sensor for the gauge. There is no harm in leaving the sensor there. It would just act as a plug.
I don't really think the engine getting hot would harm the sensor. I would worry more about other things (like head gaskets) if it really got way hot.
KYWes
Jun 14, 2022 06:52 AM
Noct
Jul 14, 2015 01:18 AM
asilomar244
Jul 12, 2015 05:53 AM
SergheiS
Jul 5, 2015 03:27 AM
AWYEE
Parts Wanted
May 12, 2015 06:58 PM
