where to buy a longer dowel pin?
Old Jul 30, 2004 | 11:10 AM
97Z-pimp's Avatar
Just like the title says, where can i buy a longer dowel pin? thanks
Old Jul 30, 2004 | 11:28 AM
speedmiser's Avatar
Re: where to buy a longer dowel pin?
If you want a new dowel pin for the cam, you can get one from comp cams. Call them directly.
Old Jul 30, 2004 | 12:08 PM
ibanez6rg's Avatar
GMPartsDirect also sells them.
Old Jul 30, 2004 | 12:20 PM
97Z-pimp's Avatar
do you know the part # for the long dowel pin?
Old Jul 30, 2004 | 02:29 PM
speedmiser's Avatar
I didnt give comp a number when I got one from them. I told them that I had bought a cam from them, then I had switched from non-vented to a vented opti. They sent me a new pin for free (no shipping charges either). I installed the pin and trimmed it to length - you can run a search for the correct length - I've seen it posted many times. Whether you get a pin from Comp, Crane, or GM, make sure you check the installed length before re-installing the cam.
Parts Wanted
May 20, 2015 10:48 PM
RiverMutant96
Jan 30, 2015 09:21 AM
sscott
Jan 17, 2015 04:30 PM
Hurin
Dec 13, 2014 07:38 PM
