Sound Clips of 227/233 Cam
Re: Sound Clips of 227/233 Cam
From what I have heard from many people, this cam does not work well with an auto and stock headed car even if the car has gears and steep converter to get into the power ban quicker. The cam is high lift with 1.6 you will be running 560 and 569 on the lift numbers.
from what I was told, This was a good cam. He suggested 1.6 RR, hardened pushrods, and all the usual stuff. A guy I know is running the CC306 on stock heads and if I am right, that is a much bigger cam. What will happen if I run the 227/233? It will be getting dyno tuned.
