Where to buy 58mm TB gasket?
Old Sep 14, 2003 | 11:13 AM
CamaroSS30th's Avatar
Question Where to buy 58mm TB gasket?
Hey Guys,
Where can I buy a 58mm Throttle Body Gasket? I can't find one anywhere.. Does anyon know where I can get one? Anyone have a part number? Thanks for the Help.
-Jay
Old Sep 14, 2003 | 12:10 PM
Compstall's Avatar
Did you try just buying a standard TB gasket and using an X-acto knife to match the holes up?
Old Sep 14, 2003 | 12:12 PM
RamAir95TA's Avatar
Yeah, just buy a stock gasket and cut it larger to fit.
Old Sep 14, 2003 | 01:25 PM
Mikey97Z's Avatar
Actually I tried cutting one of those black stock TB gaskets with all kinds of blades and I can tell you that it is really hard to cut it, and damn near impossible to cut it cleanly. It came out looking like crap. I have an AS&M TB and I ordered some new 58mm gaskets from them. Theirs are just thin yellow paper (and overpriced at $4.50 a piece) but still way better than hacking up a NAPA gasket.
Old Sep 14, 2003 | 03:07 PM
silverz28's Avatar
I just bought a 58mm TB gasket from Thunder Racing for 5.50.
Old Sep 15, 2003 | 02:33 AM
Compstall's Avatar
If you're ambitious enough you can make your own. It's not hard.
Old Sep 15, 2003 | 03:07 AM
AndyB's Avatar
Stock sized gasket + dremel tool/razor blade = 58mm gasket
Old Sep 15, 2003 | 06:54 AM
SinisterSS's Avatar
Screw the gasket. Silicone is your friend.
Old Sep 15, 2003 | 08:35 AM
AxeGrinder30thZ's Avatar
I know Summit has aftermarket throttle body gaskets.
Old Sep 15, 2003 | 09:05 AM
LeftoverChinese's Avatar
If you want a gasket to port your intake manifold, then I would get one that goes with your TB. Some are different than others.
Old Sep 15, 2003 | 10:01 AM
madwolf's Avatar
Yep, I also "ported" mine with a dremel... Works very well and looks like it's been cut by a machine....
Potent77
Mar 16, 2022 12:13 AM
Peytons'z
May 6, 2021 09:25 AM
maybe2fast
Mar 26, 2015 08:34 AM
Queens94z28
Dec 20, 2014 09:11 PM
