where is the air pump located?
been blowing the fuse on it causing the ses light on my 94 t/a so im gonna disconnect it then toss a good fuse and the light should go out. Just wanna know where the damn pump is to disconnect it.
three bolts take it off with its bracket.
Here's a pic, courtesy shoebox's site
http://shbox.com/1/temp_sensor1.jpg
Some more views here.
The tube that comes from your cai or airbox goes directly into the airpump. 3 bolts take it out and then 1 more bolt for the electrical connection up a little higher. You will also need to cap your manifolds and take out the long pipe that goes over and connects to the passenger side manifold. You will also need a vacuum cap for the cai or airbox.....I used a 3/4 inch cap.
Yea I dont think anything bad will happen other than the check engine light. Yesterday I was bored and I took out my air pump leaving the egr on and the pipe that goes over to the pass. side blocking the manifolds and cai of course. I'm gonna take the egr and pipe out next week when I get some time, but so far I havent even thrown a code.
