where is the air pump located?
Old Jun 5, 2004 | 08:53 AM
  #16
Josh'95Z28conv's Avatar
Originally posted by gritter
i was talking with a hoist or a jack....
So when you talk about a hoist or jack, you say "do I have to adjust the height of the car?" WTF do you expect people to think with a dumbass question like that. Ask if it can be done from the top, or if you have to jack it up and get it from underneath
Old Jun 5, 2004 | 09:22 AM
  #17
RamAir95TA's Avatar
Originally posted by screamin94Z
only asking because its too late to go out and mess with the car, but do you have to route the belt different to bypass the air pump or does it require a smaller belt?
The AIR pump is electric, and does not need a belt.
You don't need to give him a smart-*** comment like that. He's asking questions that he would like answered.
Old Jun 5, 2004 | 11:10 AM
  #18
MarkyMark's Avatar
I just put the front of my car up on rhino ramps and did it from the bottom for 2 bolts and top for the 3rd bolt and the vacuum solenoid bolt. After everything was disconnectted I just pullled it out from the bottom.
Old Jun 5, 2004 | 11:36 AM
  #19
gritter's Avatar
im glad to see i got you so worked up about a poorly worded question. If all you have to say is stupid **** then STFU nobody wants to hear it.
Old Jun 7, 2004 | 05:11 PM
  #20
96WhiteZ28's Avatar
What kind of gains are possible if you take out the AIR pump?
Old Jun 7, 2004 | 05:29 PM
  #21
MarkyMark's Avatar
No gains it just cleans up your engine bay and makes you a few 5 or so pounds lighter. People also say that your car may run a little cooler, but im not too sure about that.
Old Jun 8, 2004 | 03:50 AM
  #22
gritter's Avatar
ok i cut the wires going to the air pump replaced the fuse, and the fuse still blew. What could be wrong?
Old Jun 8, 2004 | 04:20 AM
  #23
RedHottG2's Avatar
Dude, if you dont have an answer to his question than get off his nuts. I've been working with him for about a week now and what he has to ask is very important. True he may not ask it in the best of terms, but he gets the point across to people that can understand and are willing to help. Everyone I have talked with including myself are stumped with his problem. so unless you have something informative to add please stay out of this thread.
Old Jun 8, 2004 | 08:13 AM
  #24
Hopefully you cut the right wires, but I don't see why you wouldn't just unplug it. Does it blow immediately or when you start the car? Try removing the AIR pump relay and see what happens. It could be the relay or wiring shorted past the relay. Swap the relay with the fog light relay and see if the same thing happens. Test the AIR pump relay in the fog light socket to also verify if it [fog lights] works.
Old Jun 8, 2004 | 10:15 AM
  #25
gritter's Avatar
It usully blows after about 3-5 minutes of running. I'm gonna go try to relay thing will get back to u in a minute
Old Jun 8, 2004 | 10:19 AM
  #26
gritter's Avatar
swapped the relays and the fogs light do work. Left them swapped and will see how that works, replaced the fuse w/ a new 20a fuse and lets see how it goes. Will let you know after i return from work. Thanks for all the help guys.
Old Jun 8, 2004 | 06:34 PM
  #27
gritter's Avatar
blew the fuse again SES light came on once again.. This time it went off when i stopped at a stop light, and after about 30 seconds of driving it came back on. Any more suggestions? I really appreciate all the help you guys have given me.
Old Jun 8, 2004 | 08:35 PM
  #28
Nestromo's Avatar
My suggention is a 1LE foglight delete kit. I've always hated the look of foglights on an LT1 Camaro. Is your car a Camaro or a Bird?
Old Jun 8, 2004 | 09:47 PM
  #29
I originally posted a sarcastic comment. He replied with a smart *** comment. I responded back with a smart *** coment. He's the one that got all serious
Good luck with getting the ses light off. All I did was unplug my air pump, and never got a light or anything...
Old Jun 9, 2004 | 06:57 AM
  #30
GRndPNdN93Z's Avatar
no you wont have to worry about the belt having to be any shorter, becuz the air pump on our cars is not belt driven, its all done by an electric motor.
