When you scan your car, what does a bad o2 read?
Old Sep 19, 2006 | 05:28 PM
NeoSNK's Avatar
I'm gonna buy an aldl cable to scan my car because I think I have a bad o2 sensor even though the ses light doesnt come on. I will be using freescan. What should I look for on the o2 sensor readings?
Old Sep 19, 2006 | 05:35 PM
Re: When you scan your car, what does a bad o2 read?
In closed loop, the O2 sensor readings will be swinging maybe 10 times per second between 0xx - 9xx mV's. The average of those reading shuold be 450mV. Unless your scan software it capable of reading 10 frames per second, you'll miss some of the readings.
If the readings are slow to change in closed loop, or static, there's a problem. At WOT, you'll be lookig at fairly constant values, hopefully in the 870-920mV range (depending on your apllication), but at the A/F ratios required for peak power/torque, the O2 sensors are simply not very accurate.
Might want to look at the A/F Management section of this writeup:
http://members.aol.com/InjuneerZZ/ScanMast.htm
brentbrowning01
Dec 16, 2014 06:35 AM
AlaskaZ28
Dec 10, 2014 02:37 PM
blac94Z
Nov 24, 2014 07:12 PM
USAirman93
Nov 24, 2014 03:37 PM
Brent94Z
Mar 21, 2002 04:44 PM
