When to upgrade to LT4 kock and MSD ignition
Old Dec 5, 2003 | 12:00 PM
NuMbNuTs670's Avatar
When should I get these done?
Old Dec 5, 2003 | 12:14 PM
Mike383LT1's Avatar
upgrade
a lot of people will upgrade to the lt4 knock mod. when they add roller rockers the extra noise from the rockers can play havoc with the lt1 knock as far as an msd 6 box when ever i would recomend a wire,coil,and plug upgrade at same time
Old Dec 5, 2003 | 01:13 PM
fastcamz28's Avatar
Ditto what Mike383LT1 said. I did exactly what he described; excellent results. Installed the MSD 6AL first; great SOTP mod, and followed it w/ the LT4 Hot Cam/ kit w/ new coil (MSD Blaster), MSD 8.5 wires, NGK plugs, and LT4 KM. You should feel the difference! Good Luck!!
Old Dec 5, 2003 | 01:19 PM
Zrag's Avatar
I have 1.6 rollers and feel as if it is a bit slugish does this mean
I could have a problem with my stock KM??
Where should I buy the KM? Would it be something Napa would have?
Old Dec 5, 2003 | 01:30 PM
hozb817's Avatar
Gmpartsdirect.com has the LT 4 KM for around 25.00. You can also pick one up on ebay!
Old Dec 5, 2003 | 01:54 PM
94formulabz's Avatar
I believe some people have experienced knock retard with only exhaust mods. I did the lt4 km as one of my first mods.
-brent
Old Dec 5, 2003 | 01:58 PM
93redbird's Avatar
And if you have a 93, then what do you do?
Tim
Old Dec 5, 2003 | 03:51 PM
Brandon94Z28's Avatar
I had a 94z with hot cam and rockers, headers, cut out, exhaust and had 0 degrees of knock according to my auto x-ray scanner. I also could tell no difference with the coil and 6a. Could be my but meter is broke though
good luck
Brandon
CARGASM
Sep 4, 2002 11:17 AM
Mike94ZLT1
Jul 31, 2002 01:50 AM
DirtyredT/A
Jul 29, 2002 11:27 PM
smackkk
Jul 22, 2002 05:17 PM
