when to upgrade to a higher volume fuel pump?
Old Apr 23, 2013 | 08:25 PM
Thirim's Avatar
My fuel pump is dead, my question is that I'm curious about how much HP you can make before having to upgrade to a better pump? .. IE I can save a few bucks with a good Bosch stock replacement and spend that $$ on suspension parts or should I be dishing out for the better pump?
Currently I'm a nearly stock LT1 but have trickflow 185 heads and plans of a 383 build in the near future.
Thanks.
Old Apr 24, 2013 | 12:50 AM
slick1hunting's Avatar
the racetronix pump(walbro) with hotwire kit is a popular upgrade and I believe good to around 550-600fwhp. If you dont have the trap door cut I would definately consider it.
Posted from Camaroz28.com App for Android
Old Apr 25, 2013 | 10:50 AM
KW Baraka's Avatar
Re: when to upgrade to a higher volume fuel pump?
Originally Posted by slick1hunting
the racetronix pump(walbro) with hotwire kit is a popular upgrade.......
And will run you in the neighborhood of $110 to $120.
A worthwhile alternative to stock .
KW
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
