when is the stock MAF a restriction?
Old Mar 25, 2004 | 10:56 PM
QCKZ28's Avatar
at what point does the stock MAF become a restriction?
Old Mar 29, 2004 | 03:49 AM
QCKZ28's Avatar
TTT
Old Mar 29, 2004 | 11:22 PM
Quick96Z's Avatar
i am also curious to that question. When is the stock throttle body a restriction too? I have ported heads and 230/236 and i wanna know when those should be swapped out
trav
Old Mar 29, 2004 | 11:44 PM
Red96Lt1's Avatar
TB, probably 400 to the ground.
Old Apr 5, 2004 | 01:28 AM
QCKZ28's Avatar
Old Apr 5, 2004 | 01:41 AM
bunker's Avatar
Its been a while since math class LOL, but my understanding is basicly where the 52mm TB becomes a restriction is where the stock MAF becomes a restriction aswell.
To find the area of a stock maf you go 3.14X(75)squared
so 75X75 X3.14 = 17662.5
a 52mm TB goes like this
52X52 X3.14 = 8490.56 multiply this by 2 since there is 2 holes this gives you 16981.12
So a stock maf will flow a little more then a 52mm TB will, but a 58mm tb will be 21125.92, now the MAF is the restriction if you see where I'm going with the AREA of a circle here.
to have a MAF that will flow more then a 58mm TB you need an 85MM MAF like the Granatelli or the Z06 MAF. Which will have an area of 22686.5 which is more then a 58mm TB will flow.
This ofcoarse means that your engine will suck that much lol, we are just referencing the MAF restriction to your TB size, & since ppl claim 33rwhp gains from 58mm TBs on some setups this means their maf is next on the list LOL.
Hope that helps
Matt.
Old Apr 5, 2004 | 08:36 AM
MentalCaseOne's Avatar
Here is the "lame" way I did it.....
I logged a WOT run with the MAF on the air path and One Logged WOT run with the MAF removed from the air path.
Then I compared the MAP readings..... there was less vacum build up past 3500 RPMs inside the Intake manifold with the OEM MAF removed.
Tryed it for a second time (total four WOT runs logged) and I had the same results.
Because of my stock set up I had to remove the restrictive OEM plastic conection from the MAF to the air filter on the first WOT run to even things out with the second WOT run (MAF physically removed)
Based on this test the MAF becomes a somewhat of a restriction after 3500 RPMs on my stock engine.
Marvin
Old Apr 5, 2004 | 08:46 AM
zoso1959's Avatar
Thumbs up 400 HP
From what i've been told and have read on this and other boards, the stock MAF, is good for up to 400 hp.
zoso
Old Apr 5, 2004 | 08:49 AM
bdc95ta's Avatar
bunker where does the 75^2 come from??? for the 48mm tb
..and how do you like your holley 58mm do u have any problems w/ it? I've heard of people haveing problems upgradeing there tb. I've also heard on realitively stock engines upgradeing to that size tb will actually hurt performance.
-b
Peytons'z
May 6, 2021 09:25 AM
canbaufo
May 25, 2015 12:01 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
mritter1965
Exhaust System
Feb 15, 2015 07:31 AM
MyShibbyZ28
Feb 14, 2015 12:05 PM
