when pulling the crank pulley off, does it matter where the arrow is pointing?
Old Mar 8, 2004 | 04:21 PM
sc93's Avatar
Doing a cam swap,
I got the 3 bolts out of the pulley, when I pull it off, should I have the arrow pointing a certain way? or doesn't it matter?
Old Mar 8, 2004 | 04:29 PM
If all you are doing is removing the pulley/damper from the hub, you don't need to have any particular orientation. The 3 bolt holes are not evenly spaced, and the pulley will only bolt back on in the one correct position.
Old Mar 8, 2004 | 05:00 PM
sc93's Avatar
Well i'm going to pull the hub too (cam swap)
Old Mar 8, 2004 | 05:10 PM
Dave89IROC's Avatar
the crank is not keyed, but on reinstall, the arrow should point up with the motor and TDC for #1 cyl. (crank sprocket dot at 12 o'clock)
Old Mar 8, 2004 | 06:11 PM
sc93's Avatar
So just when I'm putting it back together, make sure its at #1 TDC and put the pulley on with the arrow at 12 o clock?
Another question,
when i take the hub off, Should I mark it so that I can put it back on in the exact same position or does that not matter?
Old Mar 8, 2004 | 06:57 PM
93ZM6Tally's Avatar
As far as the balance of the rotating assembly no. It is however handy to have the arrow pointing correctly for future reference.
HectorM52
Jun 23, 2016 08:42 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
QuickSilver02
Apr 7, 2015 11:12 AM
SpeedJunkee
Jan 27, 2015 10:02 PM
