When installing the main and rod bearings............
Old Jan 27, 2004 | 02:07 PM
v7guy's Avatar
Question When installing the main and rod bearings............
Is there anything I need to do specifically when installing the main and rod bearings or is it literally just cleaning the block/rod surface thouroughly and then setting it in and tightening the bolts?
Old Jan 27, 2004 | 02:10 PM
WS Sick's Avatar
Use some good assembly lube so it wont dry start, also make sure its in there good before you torque the bolts down (locating tabs)
Old Jan 27, 2004 | 03:29 PM
I1O0O1I's Avatar
assembly lube and make sure to not get any on the bottom of the bearing surface. basically anywhere that the bearing come in contact with the block or rod cap etc
Old Jan 27, 2004 | 04:45 PM
v7guy's Avatar
clean off the outside of the bearing where it mates to the block surface as well?
Anyone want to reccomend a cleaner to use..........or we talking just some brake cleaner would work great
Old Jan 28, 2004 | 09:46 AM
SWINGRRR's Avatar
You can wipe it down, it wont hurt anything. I used barke clean.
Where in Irving do you live. I used tp goto MacAurthur High. We lived on Flintridge Dr, by DFW.
Old Jan 29, 2004 | 02:56 AM
v7guy's Avatar
I"m just off of McAuthur inbetween 183 and 635
Old Jan 30, 2004 | 09:08 AM
SWINGRRR's Avatar
HHHHMMMM, what a small world. Good luck on the motor.
LeftoverChinese
Jan 14, 2024 03:03 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
