When to clean filters?
Old Jun 27, 2004 | 08:05 PM
Cmr0z28's Avatar
Just wondering how long you guys are going before changing the filters on your SLP CAI. I bought my CAI new about ~10-11 months ago, and they haven't been cleaned since (9-10k miles). When do you recommend I clean them? Also, it's been 6 months since I took off my throttle body and MAF sensor for a cleaning, when should I clean them?
Thanks for reading,
-Matt
Old Jun 27, 2004 | 08:41 PM
simple's Avatar
i try to clean mine every 2 oil changes
but i also leave mine open to the elements (i dont put that undercar cover on mine)
Old Jun 28, 2004 | 12:36 PM
If its a K&N, do not clean it too frequently. It needs a light coating of dust to bring the filter efficiency up. K&N recommends a 50,000 mile cleaning interval - adjusted for driving environment. They also recommend that you discard the filter after cleaning it 25 times.
http://www.knfilters.com/facts.htm#SINTERVAL
Old Jun 28, 2004 | 03:17 PM
95 WHITE TRANS's Avatar
Are the filters on the slp cai really K&N.
NICK
Old Jun 28, 2004 | 03:24 PM
Red96Lt1's Avatar
More than likely. Most CAI manufacturers use K&N. I guess it cuts down on their R&D department.
Old Jun 28, 2004 | 03:33 PM
Cmr0z28's Avatar
Thanks....so 50,000 miles, I should probably be worrying more about an engine rebuild from now until then instead of cleaning my filters
J/K
Old Jun 28, 2004 | 04:16 PM
1racerdude's Avatar
engine
Shouldn't need a build with 50K,unless it has been rode very hard and put up wet (horse story)Unless you just want to go faster.
Clean the filter when it has crud packed to it and you can't see through it.DO NOT blow out with air.Wash,rinse and dry--reoil.
kxrawx
May 25, 2015 08:29 PM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
Jazsun
Dec 29, 2014 12:14 PM
