When the car is cold....
For some reason, when the car is cold, the oil pressure gauges goes to like 40-50 and stays there until it warms up then it drops to 10-20 or so. And the other thing it does is that the throttle sticks a little, it likes to hold a 1500-2000 rpm idle when the car is moving (while in neutral) but if i stop it goes down to the usual 1000. does anyone know why these things happen other than the fact its a 10 year old car?
The PCM increases the idle speed when the car is moving. 2000rpm seems a little high, but then so does 1000rpm at stand still. Stock programming for the M6 is 800rpm fully warmed up. The 100-200rpm error of the stock tach could account for your 1000rpm reading. The PCM also sets a higher idle speed, based on low coolant temperature.
What viscosity oil are you using? Looks like it really thickens up a lot when cold.
Try dabbing a little oil on the throttle body butterfly rod where the rod enters the body. This cured an rpm hang I had after cleaning the TB. It's normal for oil pressure to be higher when the oil is cold. Oil also warms up a lot slower than coolant. I have an oil temp gauge and it's usually takes about 15 minutes of driving before my oil temp reaches 180 F, whereas my coolant temp is there in about 3 - 5 minutes.
Same here with the oil pressure and I'm running 10-30 also. The oil pressure has run high when cold since I bought the car 3 years ago, before and after mods at 54k. It runs high well after the engine heats up in stop go traffic. As far as I can tell it's normal
. Sticky pressure sensor anyone??
. Sticky pressure sensor anyone??Thread
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
