When to adjust 1.6 rr's
Old Nov 15, 2003 | 11:46 PM
speedracer93z28's Avatar
i just installed some 1.6 rr's and i was wondering how often you adjust them. thanks
Old Nov 15, 2003 | 11:56 PM
95RedBird02's Avatar
Hopefully only once?? I've heard mostly that it's best to do them with the motor running. From my understanding, first adjust them with it not running, making sure that the cylinder your'e working on is at tdc, tighten until the push rod has no more up and down movement, plus 1/4 turn, go through all cylinders, then, start motor, back off one at a time until you hear it clatter, tighten until clatter stops, then, 1/8 - 1/4 turn, and tighten lock nut, and hopefully you're good to go.
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
MDZ28
11
Sep 24, 2015 09:15 AM
