When is 3'' single exhaust not enough?
Old Dec 22, 2003 | 10:32 PM
LT1ponykilla's Avatar
Well, like it says. When is it to small? Im running a 3'' catback with a 3'' in/out single muffler and a turn down. When will this need to be changed?
Old Dec 22, 2003 | 10:33 PM
FacelessZ's Avatar
Probably any time after 400 rwhp...
You'll see many people running 3.5" cat-backs right now, but I wouldn't say its necessary until you're close to 400 rwhp...
Old Dec 22, 2003 | 10:53 PM
Well, Im getting my heads ported soon and I should be in the 370rwhp range. Plus I have nitrous so Im well over 400rwhp with that. Any suggestions?
Old Dec 22, 2003 | 10:58 PM
Green97Firebird's Avatar
get da mufflex 4" bro dizzle
Old Dec 22, 2003 | 11:01 PM
FacelessZ's Avatar
You can either have custom 3.5" tubing added in place of the 3" or you can check out the 3.5" cat-back that Mufflex offers. Either way it's aluminized so once you pass the 3" mark you can't get SS if that makes a difference to you. Nobody's made one...yet...
I'd personally say that 4" tubing is a bit of an overkill though, so you'd be safe going with 3.5" tubing...
Old Dec 22, 2003 | 11:13 PM
Sup bro dizzle? The 4'' is a little much I think.
I may run dual 3''. Is that a good idea?
Old Dec 22, 2003 | 11:15 PM
FacelessZ's Avatar
Running dual 3" is VERY hard to do. You'll see most people running 2.5" duals and they can be a tight fit...
You may be able to find a shop that could do it...
Old Dec 22, 2003 | 11:17 PM
I wouldnt run it to the rear of the car. It would be dual's dumped off under the car before the axle. Not sure yet what Im gonna do.
Hey Gary talk to Trey (axegrinder30thZ on scfyb) he has dual 3" on his with an x pipe. Was done at Ragers in anderson for 210 installed...thats including the price of the bullets that you have to buy yourself
Old Dec 22, 2003 | 11:19 PM
his is also dumped before the axle I believe
Old Dec 22, 2003 | 11:20 PM
Them bullets are very loud. I dont want my car to be loud again just something that will sound good and be nice with the cam. At the same time being able to support all that damn power.
Old Dec 22, 2003 | 11:23 PM
well get a couple of those spintechs or use two flowmaster 40 series....
Old Dec 22, 2003 | 11:24 PM
FacelessZ's Avatar
In that case you could check out a Pro Flo Twister muffler or even a chambered muffler, something a bit more restrictive than will quiet your TD's down a bit...
Old Dec 23, 2003 | 12:30 AM
Thanks man.
Old Dec 23, 2003 | 08:23 AM
Shon Herron's Avatar
I have all kinds of exhaust on my car. Last count was 9 different set ups, from all sorts.....
i run 2.5" duals on it now with my LTs.
The shorties and what you are doing I would say your 3" exhaust is fine. I have had this discussion with the shop that does most of my work and he states that most 3" systems are fine and might be over kill.
Gary, stick with what you have, if you want to run a different muffler then do that. But no need getting more than you need. I have done it all, Russ is not the leader in exhaust technology. ask me...he can tell you how many different things have been on my car and I will be honest with you, none of them picked the car up. I ran 88MPH in the 1/8th with all the systems. This dual system finally got the car to 91 at WS one night, 4 runs in the 91MPH range.
If you do not run it over the axle and out the back or side it is going to be loud inside.
I do not think you will pick up anything even changing the flowmaster out. I had that one too....
