Wheelspin
Old Mar 9, 2004 | 08:54 PM
Paul94Z28's Avatar
Wheelspin
Hey CamaroZ28-
I have a 94Z28 M6 with a hotcam kit and 4.10 gears. I put down about 310 HP the rear wheels on a dynojet. I just installed a 52mm throttle body and the wheelspin on the car has gotten noticeably worse. I don't think it was just the tb, but I wanted to ask what I should do about it. I have 17x9 ss rims with 275 Comp TA tires. Should I go to a wider rim with more rubber, or just a better tire (like a drag radial)? I wanted to add heads and longtube headers soon, but I want to solve the wheelspin first as more power is just gonna make this worse.
any thoughts?
Any help is appreciated, Thanks in advance.
Old Mar 9, 2004 | 09:06 PM
Kataklysm's Avatar
I don't know if you have already but put some lower control arms on, I use the boxed BMRs, you can definitly notice a traction difference.
Old Mar 9, 2004 | 09:14 PM
LanceJoker's Avatar
Lower control arms,torque arm,beefier tires....
Old Mar 9, 2004 | 09:17 PM
Paul94Z28's Avatar
Forgot to mention...
I have spohn lcas, beefier panhard and sfcs.
Old Mar 9, 2004 | 09:18 PM
LanceJoker's Avatar
less gas on the launch maybe?
Old Mar 9, 2004 | 09:20 PM
Paul94Z28's Avatar
I have tried launching between 2500 and 4000 with pretty much the same results, wheelspin increasing the more rpm I give it.
Old Mar 9, 2004 | 09:21 PM
LanceJoker's Avatar
A set of Nittos or something may be in order
Old Mar 10, 2004 | 04:34 PM
OldSStroker's Avatar
Have you tried 'driving it out of the hole'? With a basically stock engine and 4.10s, ease it out about 1800-2000 with the clutch to keep the wheel spin down, then roll into the throttle as the tires will take it. Practice some starts. You should be able to find the sweet spot of rpm/throttle/clutch slip which gets you a 2.1 or so short time.
The 4.10s and 2500+ launch are really ovepowering your tires. If you had 3.23's you now have about 30% more torque at the rear wheels. IMO, a 4000 launch should completely cook the tires. Neat if you like smoke.
Old Mar 10, 2004 | 05:03 PM
93Z286Speed's Avatar
i agree, 2500 on street tires with 4.10 gear is too much RPM, like said befor, drive the car outta the hole and give it what it can handle and no more.. DR's would make a noticable differnce also
96_Camaro_B4C
May 26, 2010 07:57 AM
Z284ever
23
Apr 12, 2005 10:52 PM
The Anti Riced
Oct 9, 2004 05:02 PM
