Wheelspin
Wheelspin
Hey CamaroZ28-
I have a 94Z28 M6 with a hotcam kit and 4.10 gears. I put down about 310 HP the rear wheels on a dynojet. I just installed a 52mm throttle body and the wheelspin on the car has gotten noticeably worse. I don't think it was just the tb, but I wanted to ask what I should do about it. I have 17x9 ss rims with 275 Comp TA tires. Should I go to a wider rim with more rubber, or just a better tire (like a drag radial)? I wanted to add heads and longtube headers soon, but I want to solve the wheelspin first as more power is just gonna make this worse.
any thoughts?
Any help is appreciated, Thanks in advance.
any thoughts?
Originally posted by Paul94Z28
I have tried launching between 2500 and 4000 with pretty much the same results, wheelspin increasing the more rpm I give it.
The 4.10s and 2500+ launch are really ovepowering your tires. If you had 3.23's you now have about 30% more torque at the rear wheels. IMO, a 4000 launch should completely cook the tires. Neat if you like smoke.
i agree, 2500 on street tires with 4.10 gear is too much RPM, like said befor, drive the car outta the hole and give it what it can handle and no more.. DR's would make a noticable differnce also
Z284ever
23
Apr 12, 2005 10:52 PM
