Wheel spin at 4500 RPM
Old Sep 18, 2005 | 08:15 PM
cwaldt's Avatar
I've been experiencing spinning tires at around 4500 Rpm I shift right at 5000 RPM. This is only happening in 1st gear. I don't burn the tires off on take off so i don't know what's causing this. My tires are only a few months old and have alot of thread. I've got the T-56 trans. Any ideas about what's causing this and do I need to be worried. Also my tires are stock size too.
Old Sep 18, 2005 | 08:37 PM
ReNxWar's Avatar
Re: Wheel spin at 4500 RPM
Your sure its the tires and not the clutch/transmission slipping?
Old Sep 18, 2005 | 09:12 PM
cwaldt's Avatar
Don't think its the clutch and trans. Clutch is only 5 months old. Also I can hear the tires squeel when I have the windows down.
Old Sep 18, 2005 | 09:30 PM
ReNxWar's Avatar
I can only think of something suspension then.. your sure its at 4500 only, and not just the whole 1st gear? I know with my car if I floor it even after launching, my tires spin all of 1st and most of 2nd before it catches. Is this normal or semi-normal driving, or WOT?
Old Sep 18, 2005 | 09:52 PM
cwaldt's Avatar
It's WOT driving. It takes off good and then starts to spin right before I go into second. Catches in second and little and continues to take off.
Old Sep 18, 2005 | 11:17 PM
Paul87's Avatar
Could be your belts slipping, making a chirping noise and fooling you into thinking its the tires? Mine does this on WOT 1-2 shifts
Old Sep 19, 2005 | 07:23 AM
OldSStroker's Avatar
Do a couple of these runs including the 1-2 shift then go back and measure/study the tire marks on the pavement. Concrete is nice if you can find it. The tire marks, or lack thereof, should tell you what is going on.
Also have someone observe from outside the car near the 4500-5500 rpm area.
Old Sep 19, 2005 | 08:32 AM
JoeliusZ28's Avatar
4500 rpm is about the peak power for an LT1 with stock manifolds, so that sounds completely normal to me
Aneurysm
Sep 14, 2002 03:12 AM
MustangEater82
19
Sep 3, 2002 02:09 PM
kev93z28
Aug 19, 2002 12:48 AM
Chrisdude
Aug 14, 2002 06:30 PM
simple
Aug 2, 2002 03:30 PM
