Wheel spin at 4500 RPM
I've been experiencing spinning tires at around 4500 Rpm I shift right at 5000 RPM. This is only happening in 1st gear. I don't burn the tires off on take off so i don't know what's causing this. My tires are only a few months old and have alot of thread. I've got the T-56 trans. Any ideas about what's causing this and do I need to be worried. Also my tires are stock size too.
Re: Wheel spin at 4500 RPM
I can only think of something suspension then.. your sure its at 4500 only, and not just the whole 1st gear? I know with my car if I floor it even after launching, my tires spin all of 1st and most of 2nd before it catches. Is this normal or semi-normal driving, or WOT?
Do a couple of these runs including the 1-2 shift then go back and measure/study the tire marks on the pavement. Concrete is nice if you can find it. The tire marks, or lack thereof, should tell you what is going on.
Also have someone observe from outside the car near the 4500-5500 rpm area.
Aneurysm
Sep 14, 2002 03:12 AM
MustangEater82
19
Sep 3, 2002 02:09 PM
kev93z28
Aug 19, 2002 12:48 AM
Chrisdude
Aug 14, 2002 06:30 PM
