wheel hop?
Old May 30, 2003 | 07:11 PM
meandmyz's Avatar
wheel hop?
can i have some suggestions as to what would be causing my unbelieveably violent wheel hop? I was thinking maybe the struts are bad, but i think they are ok.
Old May 30, 2003 | 07:56 PM
Derrick Redd's Avatar
If your suspension is stock try a set of aftermarket lower control arms. (LCA's) After I installed a set of Hotchkis LCA's my wheelhop was eliminated.
Old May 30, 2003 | 09:02 PM
dis3as3d's Avatar
... call me ignorant but what is wheel hop?
Old May 30, 2003 | 09:39 PM
meandmyz's Avatar
whenever I lose traction they dont just spin they hop off of the ground. Really annoying, cant even do a burnout before a run
Old Jun 1, 2003 | 12:04 AM
RyanMacZ28's Avatar
Something isn't right about that ...
Old Jun 1, 2003 | 12:25 AM
norcalstreet's Avatar
Wheel hop is normal on a stock suspension. Control arms are the key. The stock control arms are weakly pressed metal. BMR makes some pretty cheap lower control arms that are good quality. Definetly get some control arm relocation brackets when you get your control arms as they position the arms at a better angle. Very important for people with lowered cars and helpful even on non-lowered cars. Get subframe connectors and an adjustable panhard bar and your car will handle like a dream.
Old Jun 1, 2003 | 12:28 AM
Wild1's Avatar
Wheel hop occurs when the rear wheel tend to bounce on a hard launch. Shocks, no struts in the rear. If you lower the suspension, you'll need to relocate your trailing arms. Otherwise you'll get massive wheel hop.
force10
Aug 10, 2015 08:30 AM
240ssLs3
Jul 13, 2015 05:06 PM
Slayer
Jul 4, 2015 03:06 PM
SAR2K
Sep 1, 2002 10:49 AM
wytblur
Aug 5, 2002 02:03 PM
