Wheel Alignment after LS1 Brake Upgrade
Old Apr 8, 2003 | 04:05 PM
Gripenfelter's Avatar
2 of the major suspension shops in town are whining that it'll take too long and its too much of a PITA to do the wheel alignment because they have to guess too much.
WTF?
Is this true. They wanna charge me by the hour instead of a flat rate.
Old Apr 8, 2003 | 05:18 PM
1BadBrd's Avatar
what guessing is involved? No whinning from my shop after i installed mine. We did find a slight bent knuckel that cause the rod end to off by 7 degrees, which = to $220 extra i had to pay to make the upgrade to work.
Old Apr 8, 2003 | 05:35 PM
Lions3's Avatar
That doesn't make any sense. Even if you swapped over the entire front end from an LS1, they could still the do the alignment.
I suggest called them back, and avoid mentioning the conversion. They're either stupid, and don't know their ****, or they're trying to rip you off.
PS: I polished the rims, and they're pretty bling bling
Old Apr 8, 2003 | 05:52 PM
Style's Avatar
Definately don't do hourly. But I wouldn't blame the shop for trying to cover their ***, though. If everything is adjusted identically, then don't mention the swap. Good luck!
Old Apr 8, 2003 | 05:57 PM
Janny's Avatar
Heck I did my upgrade 2 years ago and didn't even bother aligning it. I gave it a real good hard eyeball, and determined that camber was pretty much identical to what it was prior to the change. Toe looked about the same. I drove it for a day and it felt pretty much exactly as it did before. In 2 years I have not seen unusual tire wear.
I think I will go get it done this year though.
Soooooo, the moral of the story is, that there really is no magic involved. It is a straight up alignment, and you may be able to get away with not doing it, it is so simple.
QuickSilver02
Apr 7, 2015 11:12 AM
Jazsun
Dec 29, 2014 12:14 PM
Hurin
Dec 13, 2014 07:38 PM
