Tips for removing driver's side drain plug?
Old Apr 7, 2003 | 08:22 PM
Silver's Avatar
A big bolt (motor mount bolt if I recall correctly) is in the way. Anybody found a tool or trick to get to it? It's *****-f*cka tight!
Old Apr 7, 2003 | 08:38 PM
1994TransAm's Avatar
well PB blaster works well...let it soak....
if that doesn't work you could use a torch...but i dont recammend it.
pb blaster will work...make sure your using a 1/2 drive to get it of....need that tourqe sometimes to get stuff loose.
Old Apr 7, 2003 | 08:43 PM
eds96ragtop's Avatar
I used a couple of long extensions on my ratchet and a flexi socket thing. Then I had to have a friend of mine put it back on because he has much smaller hands then me. It helps if you remove the oil filter.
Old Apr 7, 2003 | 08:44 PM
Silver's Avatar
the big problem is getting to it. I can't get a socket on it. i can get a wrench on it but then i have no space to turn the wrench and no way to get leverage on it.
Old Apr 7, 2003 | 08:46 PM
ltlhomer's Avatar
What are you taking it off for btw? I just did my heads/cam swap and it looked like it was going to be too hard to get off and I feared breaking it off in there so I left it alone. Didn't need it off so it worked out well.
Old Apr 7, 2003 | 09:43 PM
PoorMan's Avatar
I guess your talking about the silver drain plug for the coolant. This is what worked for me. From the bottom, put a 6pt wrench on it and hold the end going on the plug and tap the other end of the wrench with a hard plastic hammer. You may need to go with a 12pt if the 6pt cann't get you lined up for the tapping.
I had my headers and y-pipe off when I did it so I don't know if those are in the way or not. I don't remember any large bolts (motor mount bolts) being in the way.
Jeff D.
Old Apr 8, 2003 | 05:58 AM
Mtrhds94Z's Avatar
Drivers side wasn't really a problem for me.. but the knock sensor was...[psgr side drain..]
Old Apr 8, 2003 | 12:44 PM
94_Z28_guy's Avatar
Wrench, and tapped the end of wrench gently with a hammer. I remember being able to get at it from the top.
Old Apr 8, 2003 | 05:58 PM
Silver's Avatar
cool. didn't think of a hammer, which is odd b/c i sure do use a hammer a lot...
Sandersen511
Jan 13, 2015 03:49 PM
Hurin
Dec 13, 2014 07:38 PM
squarehead
Nov 21, 2014 08:02 PM
Jul 4, 2005 05:00 PM
JSK333
Sep 9, 2002 10:33 PM
