Whats your compression ratio??
Old Jan 30, 2006 | 10:10 AM
roughneck427's Avatar
Whats your compression ratio and do you run pump gas and how often on the street????
Old Jan 30, 2006 | 10:15 AM
jsetzer's Avatar
Re: Whats your compression ratio??
11.7 Static 8.7 Dynamic. Hasn't started yet but I plan on running 91 pump gas.
Old Jan 30, 2006 | 01:56 PM
resa30673's Avatar
11.7 running on pump gas. pacesetter lt,hooker catback,cc503/cc1.6/beehive springs/madz28 tune/3.73. no times yet,but pulls like a MF!!!
Old Jan 30, 2006 | 04:02 PM
CALL911's Avatar
11.5 running on pump gas, sometimes I run racing fuel at the track.
Old Jan 30, 2006 | 04:21 PM
1racerdude's Avatar
The static ain't s*** it's the DCR that counts. This is cam dependent. The bigger your cam the more static ya can run and be under 9.0DCR.
This subject has been beat to death. There is a LOT of info using the search botton.
Old Jan 30, 2006 | 04:22 PM
I basicly have the same compression ratio 11.7 and cam as you does your car ping at all on pump gas with that much compression thats what im worried about it turned out i have more compression than i wanted
Old Jan 30, 2006 | 06:34 PM
streetbad's Avatar
Lt1s are very good at running that much compression. No Worries. Reverse cooling ROCKS!!!!
Old Jan 30, 2006 | 08:56 PM
rskrause's Avatar
Moderator
7.8:1
Rich
Old Jan 30, 2006 | 09:18 PM
Mindgame's Avatar
  1. 11.6:1
  2. Pump gas
  3. probably 2-3k miles per year
-Mindgame
Old Jan 30, 2006 | 09:57 PM
calfirebird's Avatar
10.4 :1 pump gas i dont think i have much to worry about.
Old Jan 30, 2006 | 10:20 PM
OneFlyn95z28's Avatar
12.5 to 1 with a 8.7 DCR on pump 92 with 10% alc
Old Jan 30, 2006 | 10:21 PM
96ta(nick)'s Avatar
11.7 Static umm 7.8 dynamic.
Old Jan 30, 2006 | 11:39 PM
fireman's Avatar
I got 11.8:1. I figured out dynamic once but I forgot, think it was just over 9.0. I run 91 octane in the fall,winter,spring and I don't drive it in the summer.
It pings in traffic in the summer here. Phoenix is hotter than most places though, sending IATs way up.
Old Jan 30, 2006 | 11:57 PM
Jameslt1TA's Avatar
11.1 to 1, 91 octane...highest they sell. runs fine.
Old Jan 31, 2006 | 01:02 AM
94Z396_0621's Avatar
12.1 compression with my 396 on 93 octane. Havent gotten the motor together yet. Just have gotten the heads and intake from Loyd Elliott today and they turned out great.
