What's wrong with this timeslip?
Old Jun 19, 2005 | 02:35 AM
lt11997's Avatar
I went to the track for the first time today. It was about 85* and humid, I was also running on street tires with 2/32 of tread left. I was running 14.1 to 14.2 and I ran one 14 and one 13.8. I know I need better tires to get my 60ft. times down.
Below is my 14 and 13.8 run:
Reaction: 0.155
60 Foot: 2.226
330 Foot: 6.018
Mid MPH: 78.92
660 Foot: 9.132
990 Foot: 11.743
MPH: 99.29
1/4: 14.092
Reaction:.494
60 Foot: 2.282
330 Foot: 6.083
Mid MPH: 80.77
660 Foot: 9.089
990 Foot: 11.592
MPH: 104.35
1/4: 13.825
Does the 13.8 run look right to you I don't see how I could trap 104 when the rest of the runs I was trapping about 99.3. Also the 13.8 run was my last run of the day with a total of 7 runs.
I would like your opinions on this, me and a friend of mine think the 104 mph trap is a computer glich.
Old Jun 19, 2005 | 07:40 AM
89385formula's Avatar
Re: What's wrong with this timeslip?
Maybe that was just a good run, It is weird that your 60ft was pretty constant. The whole time slip looks weird comparing the 2 if they were back to back. You picked up almost 2 mid track MPH as well, your almost a full .10 faster at 660ft, and by 990ft you picked up almost .20. Thats weird, i am not sure how often the computer could make a mistake like that...is it a possibility you got someone else's slip somehow? I mean, at our track...on street night...they are so unorganized they sometimes switch up the slips.
Old Jun 19, 2005 | 01:58 PM
lt11997's Avatar
We were only running one lane and everbody else that ran before and after were'nt running anywhere close to these numbers, also my buddy was watching and when I crossed the finish line it came up as 13.825 at 104 mph.
The only thing I did different from all the other runs was I did a burnout.
Old Jun 19, 2005 | 02:02 PM
buzz12586's Avatar
Thats weird because your 60ft time is about the same but you picked up 5mph. Did you not have it floored the first time??
Old Jun 19, 2005 | 02:16 PM
lt11997's Avatar
This was my first time ever at the track on my first couple of runs I just let off the brake and went. Then I started to launch it at about 1500 rpms. All day I was experimenting launching at different rpms.
Old Jun 19, 2005 | 02:20 PM
lt11997's Avatar
I was hoping for a 13.8 considering my mods and never being being at the track before. Maybe I'm just questioning it because I actually got what I was hoping for a 13.8.
Old Jun 19, 2005 | 02:27 PM
blind527's Avatar
I got a 13.8 with:
160* therm
Madz28 tune
Random Tech cat back system
LPE CAI
Bald street tires
I should be getting a 13.4-5 with my LT headers and ORY.
Old Jun 19, 2005 | 02:34 PM
lt11997's Avatar
The et I belive it's just the 104 trap I'm questioning.
Old Jun 19, 2005 | 03:08 PM
1996LT1NY's Avatar
I doubt it was an error in the timing equipment since you also picked up MPH in the 1/8 mile. There are a lot of possibilities.. I'll throw a few out here...
You might have made that run with a cooler engine than other runs. Engine temp is important to watch.
If it was cooler out near the end of the day, the resulting cooler air would help to make a little more power.
Head or tail winds will make a difference in ET & MPH. Was the weather changing near the end of the day?
Since you are new at the track it's quite possible on other runs ytou were letting off before the actual finish line. There are usually two stripes at the end of a track 60' apart. The MPH shown on time slips is an average over the last 60'. I knbow it may sound silly but I see a lot of new racers lift at the first stripe or stay in it way past the finish line not knowing exactly where it is
Old Jun 19, 2005 | 05:49 PM
Jameslt1TA's Avatar
I did the exact same thing. i ran a bunch of 14s and one 13.9 at a 104 and the others were at 101 and 99 and 102. My car wasn't running up to par though....only every now and then it would run good.
Old Jun 19, 2005 | 06:00 PM
slimdawson's Avatar
The 104 run is probably right. The others were just not as good. Maybe you picked up some knock. Maybe the motor was hotter. Lots of little things add up.
Old Jun 19, 2005 | 06:30 PM
CamaroSS30thAnn's Avatar
little things do add up , if u bring ur 60ft dow to maybe a 2.0 mid 13s are possible , teh 104 shows it
Old Jun 19, 2005 | 10:24 PM
lt11997's Avatar
Thanks for the replys. My next mods are going to be CAI and some good tires and maybe I'll hit mid 13's.
Old Jun 20, 2005 | 10:31 AM
Kreinmc's Avatar
Probably an error in the timing equipment. You don't just gain 5 mph because you had a good run. Your 1/8 mph is up 1 mph that does not translate to a 5 mph gain in the quarter. Also, it is not normal to pick up 24 mph in the 1/8 with an auto with your mods. If you trapped 83 in the 1/8 I wouldn't doubt the 104 trap.
Aaront810
Aug 29, 2020 09:34 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
fift5
11
Oct 1, 2015 10:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
Aaront810
Sep 11, 2015 11:24 AM
