whats wrong with my ac? :(
Old Aug 22, 2004 | 11:00 AM
Seal's Avatar
after my friend and i put in the cam in my car, the hose got ripped, and all the freeon leaked out... i just replaced the hose, and got it refilled with freeon, but now the ac wont engage (it doesnt do that clicking thing when u turn it on or off) it just blows normal vent air...
i made sure all the wires going from teh ac are plugged in and tight, but still no luck...
please help! its fricking 100 degrees in FL these days!!! and my window motor broke too!
thx
Old Aug 22, 2004 | 11:52 AM
Fastbird93's Avatar
Re: whats wrong with my ac? :(
Did you get enough R-134A into the system to have enough pressure to make the clutch engage??
I.E. if there's not enough pressure in the system, the A/C Compressor clutch won't engage.
Old Aug 22, 2004 | 12:15 PM
Seal's Avatar
there is...
i had it filled at a place, so i saw him put it in, he kept saying how its full as well...
i also checked to fuse to make sure its good, which it is
Old Aug 22, 2004 | 03:04 PM
indieaz's Avatar
Hook AC guages up to the car to check the pressure. THe PCM requires a certain amount of pressure to be in the system before it will kick it on. It detemines this by a pressure sensor hooked up to the AC lines on the passenger side wheel - it's also possible the sensor is no good (this happened to me and kept my AC compressor from engaging since hte system thought i was low on freeon, which i wasn't).
Old Aug 22, 2004 | 03:21 PM
hoppy95dcmss's Avatar
You should have a low pressure switch on the line or on the accumulator. Unplug the switch and make a jumper wire to jump the circuits. If the clutch engages either the freon is low or the switch is bad.
Old Aug 22, 2004 | 10:59 PM
Seal's Avatar
can i buy this sensor at disc auto parts?
Old Aug 22, 2004 | 11:08 PM
Lt1t56's Avatar
I beleive the low pressure switch can be purchased at any aftermarket parts store and you are supposed to be able to replace the switch without loosing refrigerant ( there is a schrader valve in the hard steel line that the switch mounts onto ) so you should be able to remove switch, and with switch out schrader valve will close not allowing refrigerant to excape. While back I didnt have such luck, when I removed the switch the schader valve was stuck open so I lost all the refrigerant.
Old Aug 23, 2004 | 06:00 AM
If you decide the switch is bad take it to the parts store with you. Thay make two different size switches. One is a 1/4" schrader and the other is a 10mm. You will lose a small amount of freon till the switch screws out enough to seat the schrader valve but not enough that it should make a difference.
Hoppy
Old Aug 23, 2004 | 08:14 AM
Seal's Avatar
so i dont have to do anything when switching it out? the schreder valve be closed? or do i gotta close it or something
Aaront810
Aug 29, 2020 09:34 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
fift5
11
Oct 1, 2015 10:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
Aaront810
Sep 11, 2015 11:24 AM
