What's this wire on passanger side harness?
Old Nov 13, 2004 | 11:25 PM
Mullet Z28's Avatar
The harness I'm referring to is on the passanger side. One set of wires is for the O2 sensor, one's for the knock sensor, and the other attaches to the starter. There's another that I snapped by mistake while taking off my headers and I can't tell what it is or what it's suppose to connect to. Please help.
Old Nov 14, 2004 | 12:25 AM
pillagenburn's Avatar
Re: What's this wire on passanger side harness?
if you have a 96+ OBD2 LT1 it could be your bank 2 sensor 2 oxygen sensor (for the cat)
its a complete PITA to get at ... hope you have small hands!
Old Nov 14, 2004 | 08:57 AM
Include the year of your car in the post.... not all LT1's are the same.
Shoebox has a labeled photo of a 1995 A4 harness. If its a single wire, sounds like the engine ground:
http://shbox.com/1/harness.htm
Old Nov 14, 2004 | 10:36 AM
Mullet Z28's Avatar
Yes, it's the ground wire. Thanks for your help.
Old Nov 14, 2004 | 11:57 AM
It specifically goes on the stud located here.
Old Jan 30, 2005 | 02:22 PM
Mullet Z28's Avatar
I rerouted that ground wire to a spot on the chassis because it got charred from being too close to the headers. I'm having a strange intermittent misfire now. Could inadequately grounding that wire cause this?
Old Jan 30, 2005 | 03:49 PM
You might want to ground it on the engine to see if that makes a difference. It is a computer ground.
Old Jan 30, 2005 | 04:37 PM
CCCCCYA's Avatar
That is a direct ground for the injector driver section in the computer. I'm having a random miss myself, and I'm pretty sure this is my problem. I'l be pulling the harness completely out and going over it in the next few days, so I'll let you know if it's the cure for the miss or not. I would think it is though..
Dave C.
Old Jan 30, 2005 | 09:02 PM
Mullet Z28's Avatar
Would it be OK to ground it directly to the negative battery terminal?
Old Jan 30, 2005 | 11:16 PM
Rob(94Hawk#319)'s Avatar
Yeah, it's a ground for the PCM.. I found mine burnt (along with the O2 sensor wires and connector) when taking the heads off to freshen them up. But I had no misfire, or any SES lights, or anything. Very odd I guess.
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
mattstrike
Mar 11, 2015 07:33 PM
Jan 5, 2015 07:14 PM
siguy
Nov 27, 2014 10:07 AM
Teal94V-6
Aug 31, 2002 09:21 PM
