What's this wire on passanger side harness?
The harness I'm referring to is on the passanger side. One set of wires is for the O2 sensor, one's for the knock sensor, and the other attaches to the starter. There's another that I snapped by mistake while taking off my headers and I can't tell what it is or what it's suppose to connect to. Please help.
Re: What's this wire on passanger side harness?
if you have a 96+ OBD2 LT1 it could be your bank 2 sensor 2 oxygen sensor (for the cat)
its a complete PITA to get at ... hope you have small hands!
Include the year of your car in the post.... not all LT1's are the same.
Shoebox has a labeled photo of a 1995 A4 harness. If its a single wire, sounds like the engine ground:
http://shbox.com/1/harness.htm
I rerouted that ground wire to a spot on the chassis because it got charred from being too close to the headers. I'm having a strange intermittent misfire now. Could inadequately grounding that wire cause this?
Dave C.
Yeah, it's a ground for the PCM.. I found mine burnt (along with the O2 sensor wires and connector) when taking the heads off to freshen them up. But I had no misfire, or any SES lights, or anything. Very odd I guess.
Jan 5, 2015 07:14 PM
