What's teflon got to do with it?
Old Mar 6, 2006 | 09:02 AM
edman's Avatar
I had my throttle body removed and noticed it was sooty downstream of the blade. So I sprayed carb cleaner on it because that's what was handy. After a few minutes, the sooty grundge washed off, then a dark coating started to bubble up too. So now I have too remove the teflon coating all around. What was the Teflon for, and what are the consequences of removing it?
Old Mar 6, 2006 | 09:09 AM
blackztpi's Avatar
Re: What's teflon got to do with it?
not sure what its for on there but teflon is a good sealer and lubricator in one.
Old Mar 6, 2006 | 11:47 AM
The throttle blades are coated to shed soot. Not sure if its "teflon". Generally, its a good idea to use "throttle body cleaner", and not "carb cleaner" because carb cleaner removes the coating.
oil pan 4
Advanced Tech
9
Dec 23, 2004 12:47 PM
Red95M6Z28
May 2, 2004 05:54 PM
joelk
Feb 15, 2004 09:46 PM
DonHood
Jan 2, 2004 09:23 PM
