Cold start valve/injector?
Old Mar 6, 2006 | 02:03 AM
danny525's Avatar
Question Cold start valve/injector?
Do LT1's have them? My cold start is a little slow, it turns over like its not getting fuel when its cold for about 4 seconds to long. But once started, if i turn the car off, and start it in the next 10 minutes, it will start right up. Any ideas?
Old Mar 6, 2006 | 02:29 AM
TransAm396's Avatar
Re: Cold start valve/injector?
no they dont..only TPI's. Turn the key 2 clicks(on but not started) and youll hear the pump priming.when you stop hearing that sound....then try and start it. see if that helps.
Old Mar 6, 2006 | 11:49 AM
Check your fuel pressure, and how well it holds after the pump shuts off. If it bleeds down too fast, it could be a problem with the check valve in the pump, the diaphragm in the fuel pressure regulator, or leaking injectors.
94Form
Feb 10, 2015 11:23 PM
Gtpguy
Jan 26, 2015 04:50 PM
Jan 23, 2015 01:13 PM
Britbilly
Jan 7, 2015 08:49 PM
jayblev95
Dec 1, 2014 06:55 AM
