whats the speed limit on a 94 lt1
Old May 3, 2004 | 04:04 PM
Seal's Avatar
what is it?
its not 155 is it? i thought 149 or something
Old May 3, 2004 | 04:10 PM
Depends what tires it came with... Z-rated has no limit (I think the default entry in the 8-bit PCM field is 255), non-Z rated tires were around 108-110mph.
Old May 3, 2004 | 04:12 PM
Seal's Avatar
actually T rated tires were 118
and all of'em have a speed limiter, i'm pretty sure...
Old May 3, 2004 | 04:14 PM
Z28SORR's Avatar
There's a large thread on this if you do a search. But it depends on the package. There can be either/or an rpm limiter and/or a speed limiter. Generally there seems to be two speeds, one around 100mph and the other around 150mph +.
Old May 3, 2004 | 04:30 PM
I think Madwolf had the last word in that thread:
I haven't read the whole post, but here's some info I gathered from experience.
93-95 cars with non z rated tires and an older PCM calibration were limited to 108 MPH and received a 110 speedo.
94 and 95 cars had a newer calibration from GM which raised the limit to 118 MPH.
93-95 Z-rated cars all had the speed limiter set to 255 MPH.
96-02 F cars with non z-rated tires all had 118 MPH speed limiters.
96-02 F cars with Z rated tires were all limited to 160 MPH.
Yes, it does cut fuel for that instant, both when it hits the rev limiter and/or the speed limiter.
Old May 3, 2004 | 04:34 PM
krispy's Avatar
just find an open piece of highway and see if you can get past 110
Old May 3, 2004 | 05:32 PM
Poik's Avatar
This might be a rumor, but I heard that the 30th special edition didn't have a speed limiter. Can anyone back this up?
Old May 3, 2004 | 05:50 PM
GreenDemon's Avatar
93-95 Z-rated cars all had the speed limiter set to 255 MPH - Is that the maximum speed that the computer can handle? - what is it, like 11111111 or something???
I was just wondering if you could go faster than that.
Old May 3, 2004 | 05:58 PM
Poik's Avatar
FFFFFF
Old May 3, 2004 | 06:12 PM
med_reject's Avatar
95 is limited to 255mph, and 96 to 160mph??
Old May 3, 2004 | 07:06 PM
n2ceptor's Avatar
Car and Driver tested to 152-154 mph on an oval course....
Old May 3, 2004 | 07:50 PM
med_reject's Avatar
modded 95 lt1s have gone faster without encountering speed limiters, iwas just wondering if there really is a limiter at 255mph.
Old May 3, 2004 | 07:53 PM
GreenDemon's Avatar
Well 255 is 16 squared minus one, so obviously it's the maximum number that the computer is capable of handling- so I guess there's a spot for one and there has to be a number in there.
As far as if you could remove the limiter completely with some vudu tuning, or just set the limiter at zero and see if the car moves, I dunno.
Old May 4, 2004 | 12:28 PM
Z28SORR's Avatar
Well by the time you get an engine and car built that will go 255, the computer will be the last of your worries.
Old May 4, 2004 | 02:25 PM
StangInRearView's Avatar
i have a '94 Trans Am GT which came with stock Z rated tires, ive taken it welllllll over 140 mph driving next to a friends cl 55 amg
