What's the problem w/graph
Old Apr 20, 2009 | 03:20 PM
dr97z's Avatar
http://www.cardomain.com/ride/2567183/7
Guys, check out my dyno graph now. Clean up to 6400 then dips and comes back up. Is this valve float or something else?
Thanks for the help.
Old Apr 20, 2009 | 03:24 PM
JakeRobb's Avatar
Super Moderator
I don't think it's valve float.
Almost looks like a little bubble in the fuel supply.
Old Apr 20, 2009 | 03:46 PM
dr97z's Avatar
How would you get a bubble in the fuel supply?
Old Apr 20, 2009 | 06:20 PM
96capricemgr's Avatar
Looks like they lifted.
For the rest of you the duration a .050" is 243/251.
Did they lift because they heard something???
Old Apr 20, 2009 | 06:53 PM
dr97z's Avatar
I don't think so. That's just where whatever happened, happened. Then the power starts in again, but isn't as smooth. I think it's pretty much peaked, but looks like it would carry it out to 6800-6900. I just don't know what this is. He said you could definately feel it.
Old Apr 20, 2009 | 06:55 PM
mdacton's Avatar
did you video the run?
may be a mis or ignition issue...... I have seen similar dips when a dist is starting to go out.
Old Apr 20, 2009 | 07:24 PM
dr97z's Avatar
I wasn't even there. He's been working on the car for a while. Had a lot of other issues (opti, fuel pump)
Old Apr 20, 2009 | 07:30 PM
Any chance there is a problem with the MSD equipment or Delteq causing a rev limiter to kick in?
Get that stuff out of there and start from basics. People cause themselves a lot of hassle by overcomplicating things.
Heck if you have a stock opti put it on and try again.
Old Apr 20, 2009 | 07:53 PM
dr97z's Avatar
I assume you were looking at my car domain page. Go to page 7 for updated setup. The Digital 6 box is not hooked up at this time though for that very reason, no extra variables. I would hope there's nothing wrong with the opti, since this is the second one with in 600 miles, and no the dowel pin is not to deep, right at spec .030 in to opti. No delteq, just the basics on this run. I thought valvetrain.
Old Apr 21, 2009 | 08:38 AM
JakeRobb's Avatar
Super Moderator
Pump cavitation?
I'm just guessing here...
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
