What's next? I need help.
Old Mar 7, 2005 | 09:29 PM
stonecoldz's Avatar
Arrow What's next? I need help.
hey everybody,
I'm taking my car in to get car to get motor redone. I want to hit low 12's, but it's gonna be my daily driver during the summer, and stored in the winter.
This is what i currently have but not installed yet:
Comp Cams Custom Ground LT1 Camshaft XE 224/230 ON A 114 LSA (FOR EMISSIONS)
Comp Cams Pro-Magnum Rocker Arms (self aligning)
EX Components 612 Valve Srings
EX Components 138 Ultra Light Weight Chromoly Retainers
EX Components 391 Hardened Valve Locks
EX Components 720H Hardened Pushrods
LT1 PORTED HEADS & PORT MATCHED LT1 INTAKE DONE BY LLOYD ELLIOTT.
and 1995 + opti conversion with LT4 extreme duty timing chain with sprockets.
BBK 52 MM THROTTLE BODY.
As for the bottom end, just bought this from ape:
AP-Engineering Cheap Street 355ci LT1 Shortblock
Eagle Esp Cast Crankshaft
Diamond Forged Pistons (Dished #11411)
Diamond 4130 Chromemoly Wrist Pins
Diamond Pro Select Rings
Eagle H-Beam Connecting Rods
Michigan 77 Main Bearings
Clevite Connecting Rod Bearings
Clevite Cam Bearings
ARP Main Studs
Main Block
Blueprinted & Fully Balanced
Assembly
****SHOULD I UPGRADE TO A FORGED EAGLE CAST CRANKSHAFT****
My current mods are on the bottom.
Let me know what you guys think i need.
What kinda INJECTORS? 30lbs.?
Any help you guys can give me is appreciated,
thanks
Kinglouui
May 26, 2016 11:05 AM
David Dempsey
Mar 12, 2016 12:42 AM
truecontr3
Oct 11, 2015 09:30 AM
surreybrad
Sep 29, 2015 09:00 PM
damnyankee36
Sep 9, 2015 07:06 PM
