Whats it mean when ...
Old Apr 17, 2011 | 02:32 PM
LathersR's Avatar
my cars not starting i was thinking optispark so i got messing around with it and when i push the throttle body lever to open the throttle body and let it spring back it makes a weird noise near the drivers valve cover....like something tumbling almost?
Old Apr 17, 2011 | 02:55 PM
LathersR's Avatar
Re: Whats it mean when ...
tell me its not the camshaft right
Old Apr 17, 2011 | 03:25 PM
Describe EXACTLY what happens when you turn the key to start the engine. Does is simply crank, with no sign of starting? ....does it try to start with some stumbles or misfires, but simply not start?
Have youi scanned it for codes?
Have you checked the fuel pressure?
Old Apr 17, 2011 | 03:44 PM
LathersR's Avatar
It pretty much just cranks over and doesnt seem to fire at all maybe every 15 seconds itll have a slight bump but thats about it. i do smell some gas. it was running fine with misfires the other day. i scanned it for codes got multiple codes po 100, 103, 123, 228, 300
Old Apr 17, 2011 | 03:45 PM
LathersR's Avatar
i havent checked the fuel pressure yet but i do find the throttle body making that noise when it springs back kind of odd. the guy that towed it and dropped it off at my house said it sounds like a cylinder's not firing... possibly camshaft broke?
Old Apr 17, 2011 | 04:03 PM
moparman's Avatar
The 100 and 103 are MAF codes. The 123 is TPS, throttle position sensor code. Are you sure about that 228? According to my manual, the 228 is for diesels.
Old Apr 17, 2011 | 04:22 PM
LathersR's Avatar
i cleared the codes.. 228 might have been the wrong number i think it was 174 instead. but the rest are correct. this thing will not start.... where should i?
MDZ28
11
Sep 24, 2015 09:15 AM
WPHIG2
Aug 27, 2015 06:37 AM
4586
Aug 24, 2015 11:04 PM
