what's the difference between high/low impedance injectors??
Old Aug 22, 2004 | 11:33 AM
donot_4get's Avatar
What will I need to make a low impedance injector work in my lt-1?
thanks
leo
Old Aug 22, 2004 | 12:33 PM
sssalah's Avatar
Re: what's the difference between high/low impedance injectors??
I’m sure you’ll need a new ECM like DFI or FAST, both have the ability to run low impedance injectors which the factory PCM couldn’t.
Old Aug 22, 2004 | 12:37 PM
The low impedance injectors take a larger current to operate, at least until they open, then reduce the current levels. The result is an injector that can open and close faster, allowing large flow injectors to be "turned down" to the small pulsewidths required at idle. This takes a matching high amperage driver in the ECU. There is a "black box" convertor available for the LT1 PCM that allows it to drive low impedance injectors. I don't have a link available, but you might want to try a "search", or wait for someone else to post the link.
Old Aug 22, 2004 | 01:30 PM
RCF925's Avatar
Go here for the converter box http://acceleronics.com/ I've been using it for 72# injectors for about 6months and it works great, The Low Z injectors are more responsive than the High Z and I have a little better idle.
Old Aug 22, 2004 | 04:35 PM
donot_4get's Avatar
thanks guys.. that's what I wanted to know...
BTW how muchRWHP could 50# HIgh imp/ injectors handle in a blown aplication?
leo
Old Aug 22, 2004 | 06:13 PM
RCF925's Avatar
leo
My 50#er's were at 97% duty cycle at 5700 rpm on 5psi boost. I'm at about 550 rwhp for now til I put it on a wideband and tune a little more and maybe up the boost
Old Aug 26, 2004 | 09:09 PM
arnie's Avatar
There is also a guy in Michigan that makes low impedence P & H injector drivers/convertor, that is usable for the LTx engine variety of vehicles.
No website I am aware of, but email is: DRhoads2@aol.com
Last I heard, Lingenfelter was using his low impedence injector drivers/convertor.
Old Aug 27, 2004 | 10:13 AM
donot_4get's Avatar
thanks, I'll send him an e-mail too
leo
Old Aug 27, 2004 | 10:22 AM
donot_4get's Avatar
BTW guys... are these Fuel Injectors any good?
Mototron 60lb. per hour High Impedence fuel injectors from New Era Perf.
leo
3TAS4ME
Apr 15, 2015 02:24 PM
4586
Mar 18, 2015 06:31 PM
moneyshotz
Jul 27, 2002 06:16 AM
