whats the difference between 1.5,1.6,1.7...RR's?
Old Dec 21, 2007 | 11:48 AM
  #16
Are your hydraulic lifters capable of handling 556#?
Old Dec 21, 2007 | 01:17 PM
  #17
brokegenetic's Avatar
Originally Posted by KYLE14
es i know they are roller lifters stock but all cams do not wear the same. therefore it is good to get nw lifters when you install a new cam. the cam has .490/.490 with stock heads rr and springs... i want more. it has a 114 lobe separaion, and 290/295 advetised duration. yet again i want more out of it. lunati springs with .725 max lift. open pressure 556lbs @1.250, seat pressure 142lbs@1.940. is that enough
I agree with replacing the lifters when doing a cam, if they are higher mileage (130k+).
but I think you might be running to much spring, since the cam lift is only at about .522 with 1.6rr
Old Dec 21, 2007 | 04:20 PM
  #18
Stoopalini's Avatar
.725 max lift with what kind of install height (when does the spring coil bind)? Stock LT1 install height is 1.80, but mine measured out around 1.75. At .725 lift, the spring would be compressed to 1.025
So, if 1.75 is your height, subtract the cam lift (.523) gives you 1.22 height at maximum compression of the spring. You'll be over 556lbs on full open with those springs.
I think you should seriously look at a different spring for your application.
The comp 26918s have an open load of 318@1.2 with a rate of 313 lbs/in. With .523 lift, the max compression on the spring is 1.22, which gives you an open valve spring pressure of 309.35 lbs/in with a 1.75 seat pressure of 145.65 lbs/in.
Just something to think about.
Thomas.
Old Dec 22, 2007 | 11:00 AM
  #19
KYLE14's Avatar
will definatly think about that thanks. so you guys think 1.6's would be the best? and another question do strut tower bars work like the companies say they do? or are they a little over rated?
Old Dec 22, 2007 | 11:04 AM
  #20
KYLE14's Avatar
will too much spring make it hard on the motor?
Old Dec 22, 2007 | 12:41 PM
  #21
My Red 93Z-28's Avatar
Too much spring will make it hard on your hydraulic lifters and can cause them to fail like Injuneer was suggesting.
Old Dec 22, 2007 | 12:47 PM
  #22
Might want to post that question on "Suspension, Chassis......" forum. It gets dicussed there regularly.
Old Dec 22, 2007 | 04:32 PM
  #23
KYLE14's Avatar
ok thanks.
Old Dec 22, 2007 | 11:11 PM
  #24
96' Formula WS6's Avatar
also you might want to think about installing gears and/or a higher stall converter before installing that kind of cam.
Just my .02
Xiantyl
Jul 21, 2015 05:42 AM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
Z28amustangklr
Jul 18, 2015 11:05 AM
SergheiS
Jul 5, 2015 03:27 AM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
