Whats the Diameter of 3" exhaust tubing?
Old Mar 27, 2005 | 11:41 PM
TireMarx723's Avatar
Whats the Circumference of 3" exhaust tubing?
Well i have some custom exhaust that I dont know what the heck it is, the pipe to the muffler measure 9.5" in diameter (tape measure wrapped on outside of pipe)....Which makes me think it is a 3.5" exhaust system? But i am not sure and thats why Im posting here, any help is appreciated
Old Mar 27, 2005 | 11:44 PM
ManicHaze's Avatar
Re: Whats the Diameter of 3" exhaust tubing?
first off, the diameter is the distance across the tube, not around like you measured it.
here you go: http://mathworld.wolfram.com/Diameter.html
when referring to tubing sizes, one usually would use the diameter measurement, so measure what the diameter of the pipe is, and thats your size.
Old Mar 27, 2005 | 11:55 PM
Dave89IROC's Avatar
3" Tube has circumference of 9.4245, 3 1/5" is 10.99"
Old Mar 27, 2005 | 11:58 PM
excellant, thanks a lot, and ya i meant circumference not diameter, my bad
Old Mar 28, 2005 | 12:02 AM
DavesLT1's Avatar
pi times radius squared is the correct equation so 9.5 divided by pi is 3.023943919
then find the square root to get 1.738949085
then double to find the diameter of 3.477898169
so 3.5" sounds about right
Old Mar 28, 2005 | 12:06 AM
DavesLT1's Avatar
huh??? 3" tube diamter is 7.068583471 and 3.5" is 9.621127502 remember it's pi times radius squared.
Old Mar 28, 2005 | 12:14 AM
Dave89IROC's Avatar
pi times radius squared is to get the area of a circle,
circumference is diameter times pi
"When the distance from the center to the outside of a circle is its radius (half its width), and its width is its diameter, the circumference (or perimeter) of a circle equals two times radius times pi (3.14159), or diameter times pi. The area of a circle equals pi times radius squared"
http://www.artlex.com/ArtLex/c/circle.html
Old Mar 28, 2005 | 12:20 AM
Iroc's got it, its 3" thanks again guy, thats a nice math site too
Old Mar 28, 2005 | 02:29 PM
Coady's Avatar
Tubing is measured on the outside diameter and pipe is measured on the inside diameter up to 12".
Victor Lamb
Aug 26, 2017 02:52 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
drptop70ss
May 4, 2015 08:22 PM
Jan 5, 2015 07:14 PM
