Whats Code 26 mean(evap canister)
Old May 29, 2004 | 09:49 PM
ledfootz28's Avatar
i threw a code 26-evap emissions canister purge solenoid circuit.
whats this code mean?i have my AIR deleted and programmed out.i still have my EGR on but the part taht bolts to the header somehow we couldnt getting bolted all the way down when we did the headers so its basically halfway off.im deleting that this week.is that the code 26 means though?
Old May 29, 2004 | 11:13 PM
OBE1 95Z28's Avatar
Your emissions system includes a charcoal canister (located behind the driver's side rear wheel, behind a plastic panel). On the passanger side of the intake manifold (at least on a 95) is a solenoid that allows air/fuel vapors to flow back and forth from the evaporative canister to suck up fuel fumes and to reburn them. Check to see that your solenoid connector is connected. The PCM isn't seeing a signal and throwing a code.
Old May 29, 2004 | 11:47 PM
ledfootz28's Avatar
sweet.thanks alot.is the canister located in the car near that rear hatch sub?if so i took that sub out,maybe i disconnected something i shouldnt of have
Old May 29, 2004 | 11:50 PM
ledfootz28's Avatar
isnt that soloinoid on the pass side header the egr?i just ordered block off plates that include the one on the header.
Old May 29, 2004 | 11:59 PM
OBE1 95Z28's Avatar
On a 95 the EGR solenoid is located on the driver's side of the intake in the back by the fuel lines.
The charcoal canister is under the car, not in the hatch area. If you look in your driver's side wheel well, you'll see a plastic panel towards the rear. If you pull this panel (one screw and one plastic rivet) you'll see the canister. Chances are your problem is under the hood by the solenoid. If your car has really been smelling like gasoline, then your canister could be bad.
Old May 30, 2004 | 12:02 AM
ledfootz28's Avatar
so your saying either the solenoid on the intake manifold is bad or the canister is bad?if the canister was bad however would that throw a ses.i could see the solenoid throwing a ses before a canister.how hard would it be to change the solenoid without taking the manifold off?and where can i get this solenoid.thanks alot
Old May 30, 2004 | 12:09 AM
OBE1 95Z28's Avatar
My guess is that your solenoid or the harness going to the solenoid is the cause for your code. I stated above that a strong gasoline smell around your car is the symptom of a bad/clogged canister. I'd check the connection to your solenoid (make sure it's connected, make sure the connector isn't dirty, check that the wires are burned/cut).
One of the GM internet dealers (Dal, Jason Cromer, GMpartsdirect.com) is your cheapest route for a replacement solenoid if you decide the solenoid's bad. If you've got a F-Body friend in the area, swap solenoid's with him to test your system.
Old May 30, 2004 | 12:12 AM
ledfootz28's Avatar
yea i dont smell gas inside the car.im guessing its that solenoid too.are there any pics online of what the solenoid looks like.i just looked back there and all i saw was the egr stuff and the shrader valve.
Old May 30, 2004 | 12:17 AM
OBE1 95Z28's Avatar
I'd check Shoebox's site, he has lots of diagrams.
http://shbox.com/1/4th_gen_tech1.html
Old May 30, 2004 | 12:20 AM
ledfootz28's Avatar
sweet i found a pic.i thought u meant behind the intake i didnt know u meant on the side.i ll check it out tomm,maybe the solenoid is bad.i ll let ya know.thanks
Old May 30, 2004 | 11:14 AM
DTC 26 is ONLY for the EEC purge solenoid. The OBD-I cars have no "flow" diagnostics for EEC like the OBD-II cars. Either the solenoid is burned out, the harness plug is off the solenoid, or the wires in the harness are bad.
Old May 30, 2004 | 01:33 PM
ledfootz28's Avatar
well i found what the problem is.the solenoid is fine.when i burned up my o2 sensor harnesses(pass side) i had to cut off the harnesses and crimp and try to match the wires together.i just found out that the brown wire from the o2 sensor goes to the purge solenoid and the fans.well just so happens im also throwing a fan 1 code also.the brown wire must be crossed wtih another one.im just glad i found the problem.i also tripped the SES right after this o2 wire job so this has to be the problem.looks like i have to get under there and see if i cant match em right.thanks guys.
Strick
May 26, 2015 11:41 AM
blac94Z
Nov 28, 2014 01:53 PM
squarehead
Nov 21, 2014 08:02 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
