whats the best thing to do
Old Mar 8, 2004 | 09:21 PM
pappasmerf18's Avatar
ok i am looking at a 93 z with hooker headers intake and a flow master exhaust. and gears what should that run? 1/4
also i wanna do some engine work on it. heads cam pistons intake and all. what is the best thing to do first and what will give me the best bang for my buck.i wanna go n/a. and streetible some what. i have seen 383 stroker kits and top end kits whats the best and how much can the bottem end hold with a 2 bolt main. i know its alot of questions but if i could get them answered that would be greatly apreciated.
Old Mar 8, 2004 | 09:22 PM
Robs97Z28's Avatar
m6 or a4?
Old Mar 8, 2004 | 09:23 PM
Red96Lt1's Avatar
It would help to know what transmission you have.
Old Mar 8, 2004 | 09:27 PM
Robs97Z28's Avatar
with a m6 must of the guys are runing 3.73s for street and strip apps.
Old Mar 8, 2004 | 09:29 PM
Red96Lt1's Avatar
I would say most A4 guys are running 3.73's and mose M6 people are running 4.10's
Old Mar 8, 2004 | 09:38 PM
its a m6 trans but u havent answered my main question i wanna know what mods to do and were can i get good kits at. i was thinking about strokeing it. i can do all my own work and money isnt that big of a problem
Old Mar 9, 2004 | 06:48 AM
bump
Old Mar 9, 2004 | 07:09 AM
30thannZ28's Avatar
if money isn't a problem, I would start by doing heads/cam. then from there you can stroke it with a 383 kit or 355, even 396. Don't forget the little things along the way that get costly, like a new fuel pump, injectors, programming, lifters, pushrods, CSI pump, etc. All the little things add up quick! Again, I realize you said money isn't a problem, just budget your project out and see what you want to get first. I reccommend Lloyd Elliott's head porting. It's very affordable and uses the stock casting for some really results. Unless you prefer an aftermarket shell like AFR or someone else. Good luck and have fun
Old Mar 9, 2004 | 07:34 PM
so lt4 set up all built up or keep the lt1 heads and build them?
DarkKnight
Buyer/Seller Feedback
May 11, 2015 10:03 PM
R@mpage
Apr 20, 2015 10:02 AM
Hal Fisher
Sep 14, 2002 09:36 PM
