what's bad, timing advance or retard?
Old Apr 18, 2004 | 12:34 PM
scoobysnax83's Avatar
I think I am having a brain fart here, but my car is advancing the timing 20 degrees or so at idle and about 39 at WOT. I am getting 0 degrees of retard, but I can't remember which is bad. Which one is the result of knock?
Old Apr 18, 2004 | 12:35 PM
Knowklew's Avatar
Knock will cause ignition retard.
Old Apr 18, 2004 | 12:41 PM
so my timing being advanced is not bad, right?
Old Apr 18, 2004 | 01:24 PM
TigerWoodsJr's Avatar
right, it should advance timing at WOT, although of course 2 much could be a bad thing, and im new to these engine's, but I think that sounds right on the money.
Old Apr 18, 2004 | 02:04 PM
No retard as the result of knock is good. [edit] rather, I should say, no knock retard is good
Your engine is always going to run at some level of advanced timing. Even when you get knock retard, the timing is still advanced (meaning somewhere BTDC). Clear?
Old Apr 18, 2004 | 02:50 PM
Clear as a bell, lol... Would you all mind taking a look at my datamaster log and seeing if anything seems weird. I did some normal driving and some WOT runs. Just let me know what you all think. I had an injector DC at 104.2% on the last run, but according to injuneer it is a misconception in the program and it doesn't always mean that the injector is running at 104%DC. Not sure really what he means.
Anyway, here is the log file. Thanks for looking...
Old Apr 18, 2004 | 02:59 PM
I glanced at it last night and it seemed like there were some erratic readings-things jumping around and such. I will look again when I get a little time.
Old Apr 18, 2004 | 04:21 PM
thanks. I noticed that it seemed a little erratic as well. But everything seems fine. Car pulls real well throughout the RPMs.
Feffman
Oct 9, 2015 05:42 AM
squarehead
Jan 15, 2015 07:02 PM
Noenav
Dec 6, 2014 07:35 PM
ScottZ
Mar 3, 2004 01:34 PM
