What is zero decking mean?
Old Nov 10, 2006 | 08:01 PM
wrd1972's Avatar
Looking for an understanding of what zero decking is and decking in general and why it is required?
Old Nov 10, 2006 | 08:09 PM
kline454's Avatar
top of the piston even with deck of the block at TDC, stock you have like .020 of space.
Old Nov 10, 2006 | 08:12 PM
wrd1972's Avatar
So why do you do this, to raise the compression ratio?
Old Nov 10, 2006 | 08:15 PM
kline454's Avatar
yes to raise compression.no other real reason.
Old Nov 10, 2006 | 08:48 PM
rskrause's Avatar
Moderator
Well, besides raising CR it also makes for a tighter quench distance which can make a few more hp and increase detonation resistance.
Rich
Old Nov 10, 2006 | 09:01 PM
wrd1972's Avatar
Okay here is the deal, I need to either hone or bore my cylinders. I will be installing LE2 heads with Impala head gaskets.
Is there any reason to have to machine the deks on 78K heads that have never been overheated? heads were tight before removal.
Old Nov 10, 2006 | 09:12 PM
MachinistOne's Avatar
You should have the decks machined.
Old Nov 10, 2006 | 09:14 PM
wrd1972's Avatar
As minimal as possible or zero deck?
Old Nov 10, 2006 | 09:37 PM
The deck is on the block, not the heads. Your heads should be checked for flatness and machined if needed.
Old Nov 10, 2006 | 09:40 PM
SStrokerAce's Avatar
Yeah it also gives you more head gasket choices... Decking the block helps out in lots of areas, and yes it's always a good idea.
Bret
Old Nov 10, 2006 | 09:53 PM
johnny3986's Avatar
Correct me if I am in wrong, but on my journey to my Mech Eng degree, Mech Eng 153 stands out in my head as "boring is enlarging the hole" and "honing is the refractory process that smooths out any maching marks on the inside cylinder walls and leaves a nice cross hatched surface?"
....or thereabouts....
You hone after you bore correct?
Old Nov 10, 2006 | 10:11 PM
Mtrhds94Z's Avatar
Yes but you can also just hone and freshen rings [no boring] if the wear is minimal..
Old Nov 10, 2006 | 10:36 PM
johnny3986's Avatar
like .002 or something is the general rule of thumb correct?
Old Nov 10, 2006 | 11:01 PM
With the right tooling you can hone a cylinder to whatever size you want. Boring gives you the ability to PLACE the hole, then you hone it to final size. Honing allows you to size the bore to within a tighter tolerance and give the cylinder a surface finish.
Some CNC machines can bore extremely accurately, you could with a laser etching tool bore a cylinder and then leave the surface finish to spec with a laser.... theoretically.
Bret
Old Nov 11, 2006 | 07:48 AM
wrd1972's Avatar
Thanks all. I will be square decking the block just enough to be flat.
Other than honing, boring are their any other useful things that should be done to the bock.
