What is zero decking mean?
Okay here is the deal, I need to either hone or bore my cylinders. I will be installing LE2 heads with Impala head gaskets.
Is there any reason to have to machine the deks on 78K heads that have never been overheated? heads were tight before removal.
The deck is on the block, not the heads. Your heads should be checked for flatness and machined if needed.
....or thereabouts....
You hone after you bore correct?
Correct me if I am in wrong, but on my journey to my Mech Eng degree, Mech Eng 153 stands out in my head as "boring is enlarging the hole" and "honing is the refractory process that smooths out any maching marks on the inside cylinder walls and leaves a nice cross hatched surface?"
With the right tooling you can hone a cylinder to whatever size you want. Boring gives you the ability to PLACE the hole, then you hone it to final size. Honing allows you to size the bore to within a tighter tolerance and give the cylinder a surface finish.
Some CNC machines can bore extremely accurately, you could with a laser etching tool bore a cylinder and then leave the surface finish to spec with a laser.... theoretically.
Bret
Bret
