What is your oil consumption like?
I'm curious as to what other LT1 owners get as far as oil consumption goes.
Even though my LT1 has a slight case of the dreaded intake manifold leak, I only lose about one quart of oil every 6000 to 8000 miles! Not bad at all, especially when I read about how many LS1 owners are using a quart every 2-3k. I figure if I get around to getting this leak fixed sometime, I may end up using less than a 1/4qt every 6000 miles!
Mine is down about 1/4qt every time I change the oil (3500k-4000k miles; synthetic) and I have almost 94k on the ODO.
My LT1 has been EXTREMELY reliable since zero miles on the ODO, which is the reason I'm having trouble convincing myself to crack it open and do the LT4 hot cam kit and ED timing set.
Lucky so far-----
My 97 A4 2.73 Anniv. , knock on wood, has used almost nil on 5W30 and 10W30 Mobil1. Have no intake leaks (yet!!- lucky) but valve covers started leaking not long after putting in synthetic- this must be typical?
Befor I built the 383 my z had 65,000 on the clock and didnt use any oil between 3000-5000 mile oil changes of Mobil 1. To soon to say on the 383 as I only have 900 miles on it and the oil was changed for the 2nd time at 500 miles....
RX Speed Works
Jul 24, 2015 02:25 PM
