What is your choice for rear end fluid
Old Sep 9, 2004 | 08:04 AM
  #16
Hyperspeed97z28's Avatar
Re: What is your choice for rear end fluid
GM Gear Fluid and GM additive
Old Sep 9, 2004 | 08:09 AM
  #17
ShelbyZ28's Avatar
I ended up using Mobil 1 plus the GM additive. Its has worked great.
-Bryan
Old Sep 9, 2004 | 11:18 AM
  #18
"White Knight"'s Avatar
Standard Valvoline 90-145 (<<probably wrong weight can't think of the numbers right now), with no GM additive.
Old Sep 10, 2004 | 08:13 PM
  #19
TobyZ28's Avatar
Went to GM top pick up some Gear Oil and they had the 80W90 fluid. But when reading the fine print on the back it says its GL-4 Compliant, not GL-5! Which is what the manual specs out for Limited Slip Differentials (Gl-5). They asked a mechanic and said that "thats what we use for them, along with a bottle of the additive".
The parts guy then said the additive makes the "GL-4" a "GL-5"
Can anyone confirm this? Why wouldn't it ask for GL-4 with additive ininstead in the manual rather then GL-5 w/ additive?
Old Sep 10, 2004 | 08:33 PM
  #20
snorkelface's Avatar
Originally Posted by WOT
I've used both redline and mobil 1, no pinion seal leaks ever. Synthetics not being good for performance is myth. Not to mention Redline shockproof is probably the best climbing gear oil there out there.
If you use synthetic gear oil, it will void the warranty if you have a Torsen diff. That's how strongly they feel about it.
However, just because synthetic may not be the best in this application, doesn't mean anyone said it wasn't for anything else. I use Royal Purple in the engine and trans still (even though most people say to use dino on A4s also).
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
FredM
Dec 18, 2014 01:40 PM
