MSD window switch install: where to hook tach wire to???
Old Sep 9, 2004 | 12:52 PM
DubbyZ28Camaro's Avatar
I am just getting ready to finish the wiring of my nitrous system and was wondering where to hook up the white (tach) wire to off of the window switch??? Do I hook up the white wire (terminal 13) off of the PCM, or do I hook it up at the green wire off of the ignition coil???
Any help is appreciated...
Old Sep 9, 2004 | 02:15 PM
Mtrhds94Z's Avatar
Re: MSD window switch install: where to hook tach wire to???
Do you have an MSD box? If so it goes to the tach plug on the box..
See:
http://www.msdignition.com/pdf/pn8956.pdf
Old Sep 10, 2004 | 03:43 PM
quick-z's Avatar
I hooked mine into the PCM. All I had to do was splice it into the tach wire. I can't remember which terminal it was, but I think that it was 13.
Old Sep 10, 2004 | 06:52 PM
Thats what I kinda figured, but I wasn't for sure...thanks!!
Old Sep 10, 2004 | 08:47 PM
38oldz's Avatar
Ok #13 I have 93LT1 need to know how to add tack. where is #13 ,using dakota dash. HELP . got 4 plugs on pcm ,need to know what one
mr28
Apr 20, 2016 05:44 PM
grgguy
17
Feb 23, 2015 07:57 PM
ldtantlinger92
Jan 19, 2015 01:26 PM
mr28
Nov 23, 2014 11:11 AM
