what are your 60ft times???? Help others with thiers!!!
and if you are so inclined what degree of pinion angle are you at , what do you have for suspension mods, and also what tire size and brand are you using
Thanks Steve
hopfully this thread will help other in thier quest of a better 60ft.
Thanks Steve
Completely stock suspension, springs, shocks, control arm, and torque arm. Removed front sway bar. 4.10 gears. 3200 stall, 26x10.5x15 M/T ET Streets. Stock motor from throttle body to oil pan.
How about 1.73?
How about 1.73?
Lakewood LCA's, Jamex Springs, Kumho Ecsta Supra 712 tires 275/40/17.
86 Trans Am 305 TPI 5 Speed, 3.42 gears, 2.03
96 Trans Am 350 LT1 6 Speed, 4.10 gears, 2.06
Both cars have the same suspension mods and were running the same wheels and tires.
I Have 12 way QA1's up front,3 Way CC shocks out back, BMR trac-pak with 3 degs PA, BMR drag swaybar, and run 27x11.5x15 Hoosier QTP's. My best 60 ft is a 1.54, but I'll average around 1.56.
Randy
Randy
lakewood lower control arms, relocation brackest set to middle setting, bfg drag radials @ 25 psi, poly tourqe arm bushing, no front sway bar, 4.10 gears and leaving at 4000 rpm=1.88 60 ft spinning
thanks for all the replies the reason i ask is I just bought a moser 12 bolt, 26x11.5x16 e.t. streets and a spohn trq arm. the car already has mac lca and mac panhard bar so hopefully ill be in the 1.5
-1.7 range!!!
And I wanted to see what you guys had also so i could see what works and what doesnt. and ofcourse what pinion angle you were at so i could set mine : ) for test and tune tonight
im running tonight for the first time with this setup so ill post what i ran after tonight my current best is a 1.9 on nitto drags with a stock trq arm, with the mac lca and panhard bar
Thanks Steve
-1.7 range!!! And I wanted to see what you guys had also so i could see what works and what doesnt. and ofcourse what pinion angle you were at so i could set mine : ) for test and tune tonight
Thanks Steve
Uniroyal tires with no thread left on them.
