What is wrong with my Z28??
Update: THe light and the fans do come on when the car first starts, sorry for saying this before. But also I went to autozone to get my computer checked and the little thing they kept on pluging into the computer just kept on getting an error message.
Have you checked the fuse yet? Instead of having to take it to Autozone, just lift the hood and check the fuse block located near the driverside fender well. If your fuse is blown then you know what the problem is!
I checked and yes the fuse is blown, so I'm just going to replace it and see how long it takes to blow the second fuse. BTW does anyone have any ideas as to why autozone could not scan my computer?
hi i just bought my 94 z m6 yesterday and i have the same prob i looked and the 20amp fuse is blown so what do i do to fix it ?
also im missing the asr relay that controls wheel spin
anyone has the part number or should i leave it like that?
thanks
thanks
Originally posted by cridom
i just saw my console and i dont have any asr switch near the lighter but i still see the low trac light in the panel when i turn it on wtf?????
Re: WTF is wrong with my Z28??
Yeah im having the same problem i push the button nothing happens at all at first i thought it was the button but i never crossed my mind to check the fuse. I have a 96 z-28
Well i have that same problem, BUT my fans do not come on. I had it scanned and it had something to do with the fuel sending unit.
The SES light stays off at a light, but when i give it gas it comes on.
Nothing major that i dont think can hurt anything..
What do you think SHOEBOX?
Thank you search function. Was having the same problem, SeS light would come on after driving for a few minutes, stay on constantly, then shut off after idling for 10-20 seconds at 500 rpm. As soon as I started moving again (or raised the rpms above 500) the light would pop back on. Just ran out with the flashlight, pulled the air pump fuse, and it's blown. Hopefully that's all it is, Autozone can't scan my '95.
Deadbolt24
Jan 19, 2015 01:29 PM
DrMilhouse
Oct 2, 2002 05:03 PM
