What is wrong with my Z28??
Old Feb 23, 2003 | 09:08 AM
  #16
Greasepunk's Avatar
yeah I know what you were sayin, wasn't tryin to say you were wrong either, just throwin in my .02
I wouldn't flame a guy who helps out as much as you do!
--Tim
Old Feb 24, 2003 | 08:02 AM
  #17
Cerwin Vega Fan's Avatar
Update: THe light and the fans do come on when the car first starts, sorry for saying this before. But also I went to autozone to get my computer checked and the little thing they kept on pluging into the computer just kept on getting an error message.
Old Feb 24, 2003 | 12:55 PM
  #18
Rich_z28's Avatar
Have you checked the fuse yet? Instead of having to take it to Autozone, just lift the hood and check the fuse block located near the driverside fender well. If your fuse is blown then you know what the problem is!
Old Feb 25, 2003 | 08:13 PM
  #19
I checked and yes the fuse is blown, so I'm just going to replace it and see how long it takes to blow the second fuse. BTW does anyone have any ideas as to why autozone could not scan my computer?
Old Feb 25, 2003 | 08:21 PM
  #20
96ltz's Avatar
You have a '95 right? I think autozone only scans '96+ (obd2).
Old Feb 26, 2003 | 05:10 PM
  #21
cridom's Avatar
hi i just bought my 94 z m6 yesterday and i have the same prob i looked and the 20amp fuse is blown so what do i do to fix it ?
also im missing the asr relay that controls wheel spin
anyone has the part number or should i leave it like that?
thanks
Old Feb 26, 2003 | 05:19 PM
  #22
cridom's Avatar
i just saw my console and i dont have any asr switch near the lighter but i still see the low trac light in the panel when i turn it on wtf?????
Old Feb 26, 2003 | 05:32 PM
  #23
snorkelface's Avatar
You don't have traction control. Even if your car isn't equipped with traction control, the light still works.
Old Feb 26, 2003 | 05:51 PM
  #24
cridom's Avatar
thanks i figured it out because i think it shows low trac because of anti lock
what about the fuse?
do i put a 20 amp or 25 on the air pump?
Old Jan 5, 2006 | 01:32 PM
  #25
Evol88's Avatar
Re: WTF is wrong with my Z28??
Yeah im having the same problem i push the button nothing happens at all at first i thought it was the button but i never crossed my mind to check the fuse. I have a 96 z-28
Old Jan 5, 2006 | 01:35 PM
  #26
Scanmaster tells me one trouble code is the cooling fan circuit and the other is the EGR recirculation circuit.
Old Jan 5, 2006 | 05:38 PM
  #27
crAzy95z28's Avatar
Well i have that same problem, BUT my fans do not come on. I had it scanned and it had something to do with the fuel sending unit.
The SES light stays off at a light, but when i give it gas it comes on.
Nothing major that i dont think can hurt anything..
What do you think SHOEBOX?
Old Jan 5, 2006 | 07:47 PM
  #28
Dayum! Three year old post? Talk about resurrecting the dead?!
Old Apr 21, 2008 | 09:23 PM
  #29
MaximumJavelin's Avatar
Thank you search function. Was having the same problem, SeS light would come on after driving for a few minutes, stay on constantly, then shut off after idling for 10-20 seconds at 500 rpm. As soon as I started moving again (or raised the rpms above 500) the light would pop back on. Just ran out with the flashlight, pulled the air pump fuse, and it's blown. Hopefully that's all it is, Autozone can't scan my '95.
Old Apr 21, 2008 | 09:27 PM
  #30
This thread is over 5 years old now and still helpful. The archive should get a pat on the back!
Amen to the search function, too!
vb95z28conv
Jan 27, 2015 08:32 AM
Deadbolt24
Jan 19, 2015 01:29 PM
ldtantlinger92
Jan 19, 2015 01:26 PM
DrMilhouse
Oct 2, 2002 05:03 PM
Ryabut98
Sep 3, 2002 11:45 PM
